Intement check engine light on 91 X | Ford Explorer Forums
91Exploda
Salem N.H
91 XL
i have the CEL come on a few time in my X. I used an old tool to get the codes. i have the flowing codes, 077, 021, 030, and 041. If anyone knows where i can get discriptions for these codes on-line that would be the ballz. I used and old diagnostic scanner that did not come up with discriptions like the new ones we have today.:confused: :banghead: dame CEL
All of those are normal except 30
Well, normal if you don't go through the self test procedure and start the engine cold. I have no listing for a 30. All the 30's are for EGR problems and I don't believe you have one on that engine. Try pulling them again.
batauto.com has a section that lists the codes and the procedure, scan down to the two digit code table.
Ok i got some good info from that site MrShorty. I know my problem.
So what was the problem and solution?
Thanks:rolleyes:
