- February 7, 2003
- Mountain Home AFB, ID
- No more Exploder
That's a new one for me. To the best of my knowledge, all Explorers after 1995 had 4wheel discs. The 01 'trac my wife and I were looking at had rear disc. Here's a great thread on rear disc conversions IF you needed it. The only brake lines you will need to replace is on the axle ifself. The master cyl will also be large enough on your model as well. Anything with a 1" bore is just fine for 4wheel discs. Wilwood makes a rear disc kit for less than $500 with vented rotors and four pistion calipers that is also bolt on.
Your 8.8 will be fine even with a V8 swap or a Supercharger, or both. This is the same axle under F150s with a smaller bolt pattern and brakes.
If Rick himself can run a 8.8 rear and not break it, you will be fine.
Just to humor me, could you post a pic or your rear axle with the brakes?
