Interior courtesy lights & power windows don't work | Ford Explorer Forums
fordsRfun
hailey, ID
97 awd v8 xlt
I was replacing one of the courtesy lights in the bottom of the door panel when the bulb broke. I used a pari of needle nose to remove the remaining part of the bulb, there was a small spark, and now my windows won't roll down and my interior lights won't work!! My chimes still go off when the key is in the ignition and everything else works fine...HELP I have checked the fuse and it is ok, the same fuse runs my power seats and those still work:(
Check Fuses #8 and #10 in the Power Distribution Box (under the hood, LH fender). Also check Fuse #27 in the Interior Fuse Panel (LH end of dash). Those fuses supply voltage for the Accessory Delay Relay which supplies voltage to the Power Windows.
