EricPinMidway
- January 13, 2020
- Midway, KY
- 2017 Explorer Limited 4WD
My 2017 Limited was great up to just under 100k. About that point, got in at the grocery and the touchscreen wouldn't come on. Was near the dealer so drove straight there. Of course, when I got to the dealer and got out to talk to service advisor I turned it off. When I restarted, the screen came back like normal. Advisor says sometimes it just needs to reset, nothing to worry about and unless they see it and diagnose, Ford won't cover under warranty. I later learned from this forum that it's a frequent issue with the APIM module and I'm now past warranty so if I fix it'll be out of my pocket.
More recently, I've had intermittent issues with door locks. The driver door wouldn't lock or unlock with the proximity button on the handle - I had to use the fob or the numeric pad on the door. After a week or two, started working again. last week, the front passenger door won't lock/unlock unless you physically push the lock button down when you get out or pull the door handle from inside to open. All other doors lock/unlock fine. Research indicates possible issues with the BCM.
I'm very disappointed with the electronics in this vehicle. I had an 03 Honda Odyssey with 300k miles and no electronic/electical issues - everything that I've had to do on it was mechanical wear/tear you'd expect with that many miles. 1999 silverado - same thing, still no issues. I know there are lots more computers running these newer cars but I'd expect them to last longer than the loan payments. This was the first Ford I've ever owned and will probably be the last - very disappointed and frustrated.
