ericjames525
- April 30, 2007
- Gainesville, FL
- 2000 XLT
I have recently begun having problems where the rear-wiper will not turn on. I have discovered that occasionally, if I turn the switch on before I turn on the car, it will fix the problem. Other threads on this issue have said to try replacing the motor, and to check the ground, but this almost seams more like an electrical problem, not mechanical. Is it possible for the relays to go bad? Is there way to test the relays?
I am trying to avoid having to open up the door panel to get at the actual motor, but if thats what it takes, then I will.
I appreciate any help!
