beetlebz
- September 29, 2008
- Connecticut
- 1994 XLT
Sooo I went through the whole thing when I got my 94 xlt last week. aside from brake work, I removed the MAF and cleaned all the black crap off it, ran the tank almost dry and added a tank of high octane (91), added a can of seafoam to the gas tank, changed the oil, oil filter, checked the air filter, and new plugs and wires. The truck runs AWESOME! Until....
after running for a short while, whomping the gas will pop the CEL. shut the truck off and it goes away, until a while later, when you whomp the gas again. the plugs on the drivers side were all white... possible O2 sensor issue?
then im having rough running issues but its weird. If the truck has been sitting all night or for a long time, it will fire right up and run smooth. If you shut it off, and start it up again within an hour or two, about 40% of the time it will run rough, almost like its misfiring or skipping. not REALLY rough, but shutting the truck off and turning it back on will fix the issue instantly. any ideas?
