cburns
- September 23, 2015
- Las Cruces, NM
- 2002 Ford Explorer XLT V6
Starts up fine. Idles fine in park. When in drive and not moving, it stumbles every like 20-30 seconds. RPM drop do 300-400 for a second then go back to normal. Never stalls here. While in gear and stopped it idles at 600rpm.
Also, when shifting to reverse the engine will die about half of the time. If it does die, it generally won't die on the second try.
It has a brand new IAC, and I will try cleaning the MAF. Anything else I should be looking at? Check engine light never comes on and it runs perfectly while on the move.
Thanks in advance.
Thanks in advance.
