Vern Kleist
- July 12, 2003
- La Mesa, CA
- '94 Sport
Hi Folks,
I have a 94 sport, 5 speed, 4x4. A nice little truck.
My windshield wipers are acting up. Hi and low speed work fine but when I select the intermittent setting the wipers behave funny.
They will jump an inch or so and then sit still for a few moments and then jump another inch or so. If you set it on fast intermittent the time between jumps is 10 seconds or so. If you set it on low speed intermittent it takes much longer between the jumps.
Looking at the diagrams it appears there is the multifunction switch, then some other doohickey and then the motor.
Does anyone know if this behavior is caused by the multifunction switch or the doohickey? The switch is $100 plus and I hate to blow the money if it is not the problem.
Thanks,
Vern Kleist
v.e.k@cox.net
Thanks,
Vern Kleist
v.e.k@cox.net
