Introduce my self | Ford Explorer Forums
Introduce my self
David Bui
Seattle,Wa
Hi !
My name is David Bui . I am working as electrician helper for building construction jobs .
- I am single . my hobbie is fix my car and fishing by rod and cast net .
- I just bought the used Ford Explore 2010 _ 4 X 4 . When I filled up the Gasoline , I did not see the FUEL CAP . It just has the metal curve shaped as the chinese soup spoon handle which blocked at the gas tank hole that we used to put the nose of gas gun in to fill it up .
- I am really appreciated any friend to help me to know this problem .
Thank You Very Much .
Sincerely.
Welcome to the Forum.
Most newer caps these days use a cap-less gas tank.
No more gas cap to worry about.
Thank You Mr Shucker1 that you solved my worry.
Thank You very much.
Sincerely
