iLoveMyExploder
- October 11, 2015
- Texas
- 1993 Explorer XLT 4X4
1993 exploder 4X4. I just bought this truck the other day. I know nothing of its history. I went and started it up today and it had erratic idling when it was cold. but once it is warm, it idles normally.
the RPMs fluctuated between the normal idle speed and maybe up to +500 RPM at the highest surge. frequency and RPM speed exactly the same every time. when it idled high- it lasted for one maybe two seconds, idle went back down to normal for a second or two then idled up again. I didn't stop-watch the timing on this, but it seemed steady the whole time. it did this over and over again for 3 to 5 minutes until it warmed up some. and once it warmed up- it acted normal from then on.
I looked at the vacuum lines, and they all looked like they are in decent condition, some of them are brand new. I already know the engine idle speed is non-adjustable from its factory setting.
any ideas why it does this?
thanks in advance for comments
PS: possibly related problem?... when it runs awhile, and after its hot... if it sits for a long time (such as while stopped and waiting for a light to change), the RPMs lower... it will bog down a little bit but not so low that the engine quits running. possibly related? or is this a different issue?
