is it possible to install struts insted of shocks in a 2005 4x4 sport trac | Ford Explorer Forums
ajrodriguezt
Monterrey, N.L. Mexico
1999 4x4 Extended Cab Std
Hi, does any one tried to this?
Why would you want to? You can beef up the lower control arm and run a coil over shock, but the way struts work you’d need a fully custom set of arms, and steering.
Yes, I want to raise the front since it is dropped like 1.5 inches.
I all ready lifted the torsion bars as much as possible.
You can’t run struts and torsion bars. Both suspend the truck. If you are at the limit of your bars, they need indexed, or new keys. You can only lift so much before you have too much CV angle. Ride will also suffer because you are gettin your lift from your suspensions avalable downtravel.
