Is it possible? | Ford Explorer Forums
Is it possible?
koda2000
x
Is it possible to replace a broken rear wheel stud on a 2000 Mountaineer w/out pulling the axle? I have to replace the rear parking brake shoes anyway, but from the pictures I've looked at, I can't tell if there's enough room to insert a new stud with the parking brake shoes out of the way. What if I unbolt the brake backing plate so that I can angle it?
Absolutely:
http://www.explorerforum.com/forums/showthread.php?t=182346
You will need this tool to install without damaging the threads. Recommend using an impact wrench, but can do with tire iron and lots of elbow grease:
http://www.autozone.com/autozone/ac...installer/_/N-2747?itemIdentifier=222512_0_0_
** Might be available as a loaner tool **
If you decide to pull the axle instead, changing a stud is simple - hammer in the new one until flush. Good time to repair the parking brakes, too.
Absolutely:
Thanks - just what i needed to know. i've changed quite a few broken studs in my time, i just wasn't sure if there was enough room to wiggle the new one in w/out needing to pull the axle out a bit. good to know you don't even have to remove the parking brake shoes.
