Is it worth it ? | Ford Explorer Forums
Is it worth it ?
Trackerforsport
Essington, pa
2003 ST 5" lift and 33s
I have a CAI it's not an expensive one so it doesn't have the heat shield and I'm scared that I'm going to hydro lock my truck offroad should I just put the stock one back in or make a heat shield with a bottom to keep water away
I know my stock intake box has often been absolutely covered in mud. I'd hate to see what that would mean if it was an exposed filter.
There's no 100% way of keeping water/ mud out but the best thing you can is to modify a snorkel to work for your ST. Their are plenty of threads and build threads on here, rangerstation, rangerforum, myst and other Ranger based Vehicle forums.
I myself will be building/ modifying a snorkel for mine since I came extremely closed to hydrolocking my motor a couple weeks ago on a trail run.
The best thing for what you have now is to sell the "CAI" because there's no barrier between the water and the filter, even with a heat sheild. Put the stock box back in with the silencer and a cleanable/ reusable air filter like a K&N or like so that when you get mud and or moisture on it you can clean and reuse it.
Ok thanks yea I have been throwing the idea around about the snorkel
Maybe ill wait till after you experiment rebel than copy what you have
