Is there room for a sub box in a sport trac? | Ford Explorer Forums
Laddy
Texas
'98 Explorer Sport
Can you fit a box under the back seat? If not where do you put the box? I'm thinking about getting on of these, it won't be until this summer but still I would like to know.
I have one under my seat in the back that holds 1 10" kicker solo and it sounds pretty good i have seen atleast 3 different people selling sub boxes for the sport tracs they are
Dual 8" Box
Single 8" Box
Single 10" Box
do some searching and its not hard to find them here is a site for 1
http://musicmooseaudio.com/ford_explorer_sport_trac_fest.html
EDIT - here is another http://www.soundoffaudio.com/item.cfm/id/2103
and this guy sells the 8" and 10" boxes also he sells the one with the kicker solo also http://www.mysporttrac.com/shared/sponsor.asp?SPONSORID=16
Heres C. wells a site sponser over at mysporttrac.com, i think he makes the ebay ones.
C. Wells Enclosures
P.O. Box 2798
Huntsville, AL 35804-2798
Email: cwells1052@aol.com
C. Wells 8" Subwoofer Enclosure
What is a C. Wells 8†Subwoofer Enclosure?
It is the Subwoofer Enclosure Ford should have built for our Sport Trac’s.
When I bought my Explorer Sport Trac I knew that I would change the Audio System to perform better than the stock system. I even listened to the Pioneer’s Audiophile System and was very upset with the low-end of their subwoofer and enclosure. I did buy one of the factory subwoofer enclosure to see if it could be modified to get a better response. I had no luck on the modification of that enclosure.
The next step was calling around to all the reps I still have contact with in The Car Audio Industry and see if any aftermarket enclosure was being made for our Sport Trac’s. What I found out was very hard for me to believe or even understand. Everyone kept saying it could not be done in that amount of space. Just buy one that goes under the rear seat. I didn’t want one that would fit under the 60% of the rear seat. I still like to lay down the rear seats if I need to. This was not the answer I was hoping for, nor would I settle for that answer. I then set a goal to design and build an Enclosure that would fit in the storage compartment of the Sport Trac. This is what the C. Wells 8†Subwoofer Enclosure will do.
This enclosure will hold a 8†subwoofer with a mounting depth up to 3 13/16â€.
It will allow you to still have storage under the rear seat or lay it down if you prefer it down for your pets.
It will produce a lower Hz response than the Factory and it depends on the Subwoofer you install how low the response will be.
The Enclosure is 0.39 cu. Ft. inside. (Which is above standard for an 8" seal enclosure.)
The Enclosure is made up of both ½†MDF and Fiberglass.
This Enclosure is built with over a quart of fiberglass resign, so the enclosure will not flex under extreme pressure.
The Enclosure comes with a quick disconnect Terminal on the right side away from the factory jack. This way there will not be any chance of the wires being pulled loose if you was to remove the factory jack.
It also comes with speaker wire and poly-fil.
There is a black outer finish on each enclosure to help seal the enclosure even more. Plus it gives the enclosure that finished look.
The Price of the C. Wells 8†Subwoofer Enclosure
The price will be $120.00 shipped to any member of www.mysporttrac.com. Be sure to include your name or Alais you use on the web site plus e-mail address and state you are from. If you are a non-member the price will be $125.00 shipped. It is free to become a member of www.mysporttrac.com so save yourself $5.00 and sign up now.
Payment: I accept PayPal, Money Orders, Cashiers Check, or Personal Checks. If you send a Personal Check it will be cashed and cleared before the enclosure is shipped. I prefer PayPal. If you use PayPal send your payment to: cwells1052@aol.com. With PayPal you can use your Credit Cards or Bank Drafts.
Click here to see additional images of this product.
For any other questions please e-mail me at: cwells1052@aol.com
C. Wells 10" Subwoofer Enclosure
What is a C. Wells 10" Subwoofer Enclosure?
This is the only custom Sport Trac 10" Enclosure made with an upward firing subwoofer. With this design it will not distort the sound of the subwoofer. It also has enough room under the rear seat to even install a speaker grille over your subwoofer for extra protection. The extra space under the rear seat will let the subwoofer roll out extremely low frequencies into the cab of the Sport Trac. The 10" Enclosure fits under the 60% Rear Seat of the Sport Trac.
Keep an eye on the Group Buys Section for C.Wells 10" Enclosures and Subwoofer Combo's.
This Enclosure will hold a 10" subwoofer with a mounting depth up to 6".
It will produce a lower Hz response than the factory subwoofer (depends on the subwoofer you install how low the response will be).
The Enclosure is 0.64 cu. Ft. inside (standard for an 10" seal enclosure.)
The Enclosure is made up of 5/8" MDF, so the enclosure will not flex, even under extreme pressure.
The Enclosure comes with a quick disconnect Terminal on the back side, away from the rear passengers floor board. This removes any chance of the wires being pulled loose.
The Enclosure also comes with speaker wire and poly-fill.
The Enclosure has a black outer finish to ensure the seal and give the enclosure that finished look.
Pricing
The price is $125.00 shipped to any member of www.mysporttrac.com. This is for just the 10" Enclosure. Be sure to include your name and posting alias you use on the web site, plus e-mail address and state you are from. If you are a non-member the price is $130.00 shipped. It is free to become a member of www.mysporttrac.com so save yourself $5.00 and sign up now.
Payment: I accept PayPal, Money Orders, Cashiers Check, Postal Money Order, or Personal Checks. If you send a Personal Check it will be cashed and cleared before the enclosure is shipped.
C. Wells Enclosure
P.O. Box 2798
I prefer PayPal. If you use PayPal send your payment to: cwells1052@aol.com. With PayPal you can use your Credit Cards or Bank Drafts. For any other questions please e-mail me at: cwells1052@aol.com
Great product!
It took awhile to arrive but it is definately worth the money. Great care and craftsmanship!
ques about solo baric for sport trac
Hello I would like to have the same box you have for a 10 inch solo baric. Can you give me the direct link to that and also what kind of Kicker you have. Thanks
