Is this a transfer box problem ? help please? | Ford Explorer Forums
Tazkb
Bolton Lancashire UK
Hi guys, last week the 4.0L 97 explorer of mine failed it's m.o.t. it needed welding around the bottom of the left hand wheel well/sill area, this was completed and it then passed it's m.o.t. then the day after when I wen't for a drive as I turned out of the drive there was a terrible juddering, as though one of the brakes was stuck on at the rear ? when I got onto the road it seemed ok then as I made a tight turn the juddering started again, it seemed to come from the middle of the car but again felt as though one wheel wasn't turning properly as though it had a locked rear diff ? it's fine in a straight line and normal corners but any slow turns set of the juddering ? iv'e tried engaging 4 wheel drive, when I do the light comes on but you can't feel anything, (my friends explorer makes a noise, flashing 4x4 light then stays on) engaging low 4 wheel drive makes a clunk
iv'e tried all modes, iv'e tried going backwards in all modes, iv'e pulled the main fuses under the hood all ok, so what could it be ? it changes gear fine and smooth, what could it be ? any help would be appreciated, thankyou
From your description, it does sound like it's stuck in 4wd...
Have you tried disconnecting the battery for a bit?
just done that today so will see what happens later, thing is the 4wd light isn't staying on, it goes off when you switch to auto ?
can you manually take it out of 4wd ? i was told there was an electric motor that you can remove and manually wind it back into 2 wheel drive ?
You can do that on a standard 4x4 t-case, but I don't know anything about the awd cases.
True.
1997 4.0L has an electric shift T case not an AWD T case.
so you can remove the electric motor and shift it into 2wd
thanks guys that is a big help
