Tazkb
- June 22, 2011
- Bolton Lancashire UK
Hi guys, last week the 4.0L 97 explorer of mine failed it's m.o.t. it needed welding around the bottom of the left hand wheel well/sill area, this was completed and it then passed it's m.o.t. then the day after when I wen't for a drive as I turned out of the drive there was a terrible juddering, as though one of the brakes was stuck on at the rear ? when I got onto the road it seemed ok then as I made a tight turn the juddering started again, it seemed to come from the middle of the car but again felt as though one wheel wasn't turning properly as though it had a locked rear diff ? it's fine in a straight line and normal corners but any slow turns set of the juddering ? iv'e tried engaging 4 wheel drive, when I do the light comes on but you can't feel anything, (my friends explorer makes a noise, flashing 4x4 light then stays on) engaging low 4 wheel drive makes a clunk
iv'e tried all modes, iv'e tried going backwards in all modes, iv'e pulled the main fuses under the hood all ok, so what could it be ? it changes gear fine and smooth, what could it be ? any help would be appreciated, thankyou
