In the pic, it's the rusty round thing in upper left center. That's the closest I can see to a possible bleeder screw on the RABS, but the nut size looks to be 3/4 or maybe 7/8!
It doesn't look like any bleeder I have ever seen. Then again, I know very little about RABS except how to change a control module and that was so long ago that I forgot most of that.
You should bleed the brakes the regular way on the older model RABS. The new systems with 4 wheel ABS require a scanner capable of cycling the ABS solenoid block.
Brooklyn, does the regular way include the rabs valve, or no? That's my big question.
I know the proper order for wheels, and I know the later models with full abs need a special dealer tool. I just don't know if rabs gets bled, and if so, where?
I assume that is a bleeder, I have an extra RABS unit in my garage and mine has a rubber cap over the nipple on that end. It should bleed out when you do the rear brakes though. A hand vacuum pump from the rear brakes should do the trick.
What is making you want to bleed it? Spongy pedal or air in the lines?
