Justin_
- March 30, 2020
- Missoula
- 98 2-DR Sport 4x4 4.10
- Callsign
- KJ7IKI
Hey guys I've been having some engine issues the last little bit here. As I mentioned in a previous post I had a bunch of misfire codes on my 98 sport with the V6 SOHC. I replaced the plugs, wires, and coils, and eventually replaced the fuel injectors once I found that the issue was a bad injector on cylinder 6. I also went ahead and at about the same time replaced the timing chain tensioners. At first I used some eBay one, but they were terrible and made rattling noises. After that I got some ones from the local dealership. When I went to put the new ones in I had a hard time getting the driver side one out with a wrench, so I pulled the sensors out of the thermostat housing, and eventually pulled out the housing and used a socket to switch it over. After I did that the ECT gauge no longer functioned and I got a overheat code once (even though it was fine). The gauge on the dash just sits dead center and does not work. Around this time I also replaced the fuel pump assembly
After all this I started having the engine run VERY rich. It would stall if it idled too long, and would almost stall if I hit the gas too hard coming out of a light. I tried poking at a few things and checking connectors, but I eventually took it to a mechanic that is reputable in town. The mechanic took 6 hours and charged me for 3 to tell me that there was a kink in the fuel return line and its actually running a bit lean now. Not a cheap bill for a kinked line, but if it works, it works.
Coming out of the mechanics shop it felt good, but after a day of driving it was throwing rich codes again, a bit sluggish coming out of stops, and not accelerating as well as it should. Nowhere near as bad, but not right. Talked to the shop and they said the next thing to do would be to replace the cats and O2 sensors. Not sure how cats would help, and I replaced the O2 sensors not 10k miles ago so I thought I would take another look at it.
Doing some research around the internet I found that when an engine starts up the fuel mixture is based on the ECT sensor, and not the O2/MAF sensors and that a bad ECT sensor can cause an issue with the handover leading to rich codes and less than perfect performance. With the ECT gauge acting up and the occasional overheat code when its running fine im thinking that /could/ be related and is what I am looking into now, but I would love to get some other ideas if anybody can think of anything better.
Thanks!
Thanks!
