It dies out immediately after starting with a rough idle. | Ford Explorer Forums
BILLYK6
Wahiawa, hawaii
'93 XLT
Nothing he's trying is working. Runs good if it does not die out. When I start it, couple chugs and dies.If it can warm up good, it runs.If I let it sit and try after an hour or so it starts but still dies. He has checked the fuel pump, filter, IAC, and some other computer stuff. No luck, please help.
Aloha
did u try takin the iac valve off and cleaning it some times they get stuck
Welcome to this forum! I've moved your thread to the stock 91-94 section. It could be a few things such as a clogged fuel filter, bad fuel pump relay, vacuum leak, IAC, MAF, spark plugs or cables. Do you have any codes?
