Jeep rims | Ford Explorer Forums
Jeep rims
00XLS
Frackville/State College PA
Explorer 00 XLS
A friend of mine is getting rid of his rims off his wrangler sahara, I believe these will work on my X? Pretty sure their 15 x 7, but what about backspacing, I'm not to knowledgeable in this area.
What year is the Jeep? The only other issue i could see is the bolt pattern.
bolt pattern is the same if it is tj yj, cherokee
i have jeep eagle alloy rims on mine, they are off set and i love them
they might fit, bolt pattern is the same, but i tried to run stock steel wheels on my explorer ,adn the rim bottom out on the rear drum of my 94, it may not be an issue, for the 95+ but it would not sit on the wms
a lot of those rims will be a 15X8 but the backspacing is 5 to 5.5 inches which may be too much
Their off a 99 wrangler sahara, he said their 15x7, I'll have to ask about the offset.
The bolt pattern was fine, I tried it on the back axle and the caliper was rubbing on the inside of the rim.
