92exp4x4
- February 5, 2003
- Covington, Kentucky
- 92 XL 2-door and others
Speaking of welding, There is a trick to removing outer bearing races from a housing or casting. If you weld a bead (MIG) along the center of the race surface, then quickly turn the peice over and tap it on the floor, the race will typically fall out. The steel deforms from the heat and it typically draws the circle of the race closer making it a less tight fit in it's bore.
We did this with forklift brake drum/hub assemblies where I used to work to get the races out. Yeah I could have used a press or hammer and a punch, but I thought it was clever.
Just food for thought...
