Just Changed Transfer case fluid... have a question | Ford Explorer Forums
97splorer
Overland Park, Kansas
'97 XLT 5.0 AWD
It only took about a quart and a half to fill up my transfer case. Thats about how much came out. I just thought there would be more in there. I used Valvoline Dextron III Mercon ATF, that is correct, right?
Anyone who can confirm That I did this correctly would be great.
Thanks-Brian
no worries you are correct the xfer case also shares fluid with the tranny but it is such a small amount that you have to fill it also kinda like the old broncoII w/the a4ld the hole is at the bottom of the tailshaft housing and is just big enough to get a tooth pic in
1 and half bottle is about right. When I did mine I tried to squeeze the last extra half quart in there. Juuussst to be sure its full. :D
