when ever i go though a pit with alot of water my X starts to idle real low then it cuts off if you have an idea what it mite be let me know thanx and its a 91xl
you're probably sucking water up through the intake into the engine. are you using the stock air intake system? if so that intake pipe is down real low and getting water in there is dangerous! all it takes is one time and you could hydrolock your engine. consider getting a KKM intake to help with this problem.
also if it stalls out and won't start, you're gonna have to remove your spark plugs and crank the engine until all of that water gets out!
