Joe in NY
- June 5, 2014
- Binghamton, NY
- 2002 Eddie Bauer V8 4X4
Hi again,
So right now I have two quirks in my 02 Explorer. One is the seat belt (the other post by me). And also my key tumbler.
To clarify, sometimes when I normally insert my key it goes in fine, but refuses to advance. The steering lock is not engaged and the vehicle is in park. Doesn't matter which way I turn the key it will simply refuse to advance. Like my seat belt problem, if I keep toying with it I will get it to work fine.
This happens less often than the seat belt problem but coaxing it into working takes longer.
Does the tumbler need a little lubrication added, maybe a little WD40 first then some white lith grease?
Any help on both matters is greatly appreciated.
Thank you,
Joe
Thank you,
Joe
