03limitedon22s
- May 4, 2012
- north dakota
- 2003 ford explorer v8
i have an 03 explorer and recently found my factory code for the keypad. the keypad doesn't light up, turn on interior lights, lock doors, or do anything. i just picked one up from the junkyard and the same thing is going on. i tested the voltage on all the pins and have voltage on 4 of 6 wires rite at the keypad. one of the 6 wires is a ground and has continuity. as a side note i have programmed keys and fobs to the truck already and everything else for the key-less entry works. do you think its 2 bad keypads? or one bad wire? any suggestions?
