jhard
- January 3, 2009
- Toronto, Ontario
- '04 Limited
So I got myself the KKM Tru-Rev air induction kit (for a 2004 4.6L V8) a couple weeks back, thinking it would do an adequate job over a K&N kit and save me a few bucks too.
After the install I did the disconnect battery to allow the PCM to start to re-learn the air/fuel mixture, but it's never ran quite right and hesitates and stutters on the highway now when it never did it prior to installation and I've driven it for a while so the PCM should be caught up by now.
Anyway, one of the installation steps is to mount the support bracket for the KKM cone to one of the valve cover studs, which I didn't even question and just followed the procedure. There was no mention of using proper ft. lbs. of torque or anything using that mounting point. Since my engine started acting funny, I removed the support bracket from that spot and hammered it out straight to reach one of the retaining bolts for the Coolant res., put the valve cover stud back in and torqued it down to spec. and now my engine is running fine again.
My question is, what would having a loose valve cover bolt do to induce this kind of behaviour in an engine, and if it would pose a problem why would KKM ask you to use that as a mounting point instead of somewhere not directly to an engine component?
This is not an attempt to defame KKM, I'm just trying to figure out what the problem was.
