Kkm vs. Ifab | Ford Explorer Forums
Kkm vs. Ifab
40893
mechanicsville,va
94 explorer
Which one is best? Which gives more power? Does the IFAB tube really contribute to the power gains? Anything. Ive looked it up on here but theres not much about the actual results from them or which is better. Thanks.
They BOTH work, they both improve power a little.
The iFab just LOOKS better. That's about it.
Ryan
what kind of gains could i expect? already have flowmaster exhaust.
the tube is not where u gain all the power from you need a new maf. the maf is the restrictive part on the intake
The KKM is nothing but a filter and an adapter; I would go with the other choice.
Explain, please???????
The tube where the MAF sensor is, is the smallest part of the intake assembly. Smaller than the stock tube. You also need a new MAF sensor that is calibrated for the extra air coming in to take full advantage of it.
Someone needs to stikie the fact that the KKM is a ripoff.
It's a simple metal adapter and a cone filter.
Both of which can be bought for under 20 dollars.
The Ifab looks cooler, and will perform better for extremley modded/boosted engines.
For those saying that swapping the maf is the best bang for your buck, BS.
I spent the money and bought the fancy ass Vortech maf meter for our trucks.
Nothin. I acually felt a slight improvement when I took it back off.
The filter and throttle body are the first two mods. Then the maf becomes restrictive.
Go ahead and do the cheaper maf swap before the throtle body if you want, but I don't advise spending the big bucks until the other stuff is takin care of.
