arm1984
- July 1, 2013
- 2000 explorer
I'd just like a sanity check on my conclusions if someone could help me out.
I've been having issues with rough idle, occasional stalling and the engine running a little rough when revs increased. I spent a day cleaning MAF, idle control valve, checked all connections sprayed carb cleaner around to check for vacumm leaks. Disconnected plugs, ran engine with MAF disconnected none of this seemed to make a difference.
I eventually borrowed a code reader today and there were no codes stored in the ECU and none generated while the engine was running. MAF seemed to give good signal and responded to throttle changes. Throttle possition read as 18% assume that is ok. The only thing I could pick up was one of the lambda sensors (Bank 1) dropped and flat lined (assume to 0V wasn't very clear on the read out) then back up again to complete the wave form. Bank 2 sensor also dropped flattened a little but always stayed above the bottom never reaching the assumed 0V.
So I from the above I believe my bank 1 lambda sensor is on its way out and needs to be replaced. Can someone confirm this is the most logical step to take or have missed something obvious? Where would I buy a suitable lambda sensor ebay? could someone give me a link.
Andy
Andy
