Large / tall oil filter for 02 Sport | Ford Explorer Forums
bullsiberry
Bedford, Nova Scotia
02 Explorer Sport
FRAM listing is PH2, anyone know what the big filter number might be ? thanks very much.
Fram PH8A
or
Motorcraft FL-1A
the ph2a is the metric one (aka motorcraft 820s).. the ph8a (or motorcraft fl1a) are standard thread (3/4 x 16 I think).. They aren't interchangable..
~Mark
This is the only extra capacity one I've seen for the metric filter (820s equiv).
Fleetguard LF3315 Oil Filter
Edit: I found more listed on the 'net...
BALDWIN B281
NAPA 551087 or1087 NAPA HAD IT IN ITS WAREHOUSE
WIX 51087
FLEETGUARD LF3315
HASTINGS LF444
CARQUEST 85592
PUROLATOR L30238
CATIPILLAR 311604
FRAM PH3616
~Mark
Hey guys, came across what looks like a good cross reference chart at
www.system1filtration.com
Would you mind having a look to see if things look alright from what you know.
Greatly appreciate everyones input here.
I don't mean to throw cold water on it...but...use the filter that is recommended. I have seen more problems from people interchanging filters..just because they screw on and the gasket is in the right place does not mean the guts are the same or the pressure capacity or anything else....usually a problem with bigger machinery...
Ok some times it is an easy long short switch..but be careful..filters are spec'd out for each application.
NAPA Gold 1087 Fits:
New Holland Combine TR75 6.0 L 363 CID L3 Ford Diesel 1980 - 1983
