slowdog
- January 5, 2006
- Upsate South Carolina
- 2000 EB Explorer 5.0 AWD
I have a 2000 EX AWD 5.0 with 90000 miles.
Like many folk, I have a rumbling, grinding noise coming from somewhere in the front driveline. I have read many posts on this forum concerning the symptoms, noises and vibrations related to problems with CV joints, ball joints, hubs, front drive axles, differentials and transfer cases. Since it is difficult to describe a noise or relate to what someone else hears, I decided to just start checking everything...
First, I noticed that it appears that my tires (stock size) have rubbed against the upper ball joints enough to keep the metal on the balljoint clean. So I jacked the truck up and used a long bar under the wheel to check for play in the lower ball joints. There was about 1/8 inch of vertical play when I lifted the wheel up and down....so I decided to replace them....although I am not sure that ball joints could cause the noise I am hearing since the noise occurs while driving straight, while turning and when under a load...forward or reverse...and the tires are not touching anything when the truck is still, even when the wheels are turned stop to stop...
While under the truck I also felt of the CV joints. The right one had some lateral play in the outer joint (by "lateral" I mean perpendicular to the shaft or side to side). When I removed the CV Axle I confirmed that it has lateral play, enough to feel it bump from side to side. I removed the boot and the grease looks good and I do not see any metal filings or any signs of wear... Should there be any such play in a CV joint?? Will a CV just wear out without leaving any metal filings?
One last question....the only local parts store with a CV in stock is O'Reillys, who sell Master Pro CV axles (their brand I guess)...has anyone had problems with those parts?
Thanks for the help!!
