jstrick01
- August 11, 2008
- Fairfax, VA
- '03 Eddie Bauer
Hello,
For the past couple of months, I have been putting almost a gallon of antifreeze into the radiator every 10 days or so. I took it to a shop today and they ran a coolant system check and pressure test. They discovered that it appears the antifreeze is "seeping" through the engine block? They said this is likely due to a hairline crack in the block or the actual block has become more porous, possibly due to metal degradation? I'm not a mechanic (obviously), but does this make sense? I don't have any white smoke when I start the truck in the AM and there is no pooling or leaking under the truck each day, so the coolant has to be going somewhere.
Their recommendation was that I likely will need a new or rebuilt engine!!! For reference, I have a 2003 Explorer (Eddie Bauer edition) with approximately 151,000 miles on it. Does anyone out there have a second opinion or some advice on how I might prolong the life of the truck in it's current state?
Thanks in advance for any advice or opinions...
