leaking antifreeze | Ford Explorer Forums
leaking antifreeze
hivolt5.0
Fort Walton Beach, FL
2003 Eddie Bauer Explorer
Have any of you had the following issues with leaking antifreeze?
The hose going from the T-stat housing to the EGR housing is seeping antifreeze where it connects to the EGR housing. I've taken the hose off, cleaned the nipples and reinstalled with better hose clamps and it still leaks at the EGR.
It also looks like the coolant "housing" where the upper radiator hose and T-stat are is seeping where the housing bolts to the head.
AND, one of my heater hoses is seeping antifreeze. I ended up putting a better clamp around it today to see if that will stop the leak.
Now none of these places is leaking vast amounts of antifreeze, but I can see the residue and evidence of the seeping around each of these areas. If any of you have had these issues, what steps did you take to resolve them?
