1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
OK, so this past week has been not so good for me, on Monday the seems on my Radiator separated, after leaking for a weeks. I had to go to a shop to get it replaced because the weather around here was 7 degrees Fahrenheit, I got it back and all seemed great, no leaks, I am happy. Well yesterday after work, I noticed a wet spot under the truck, I looked and it was F*&$#ing OIL!!!!! I had pride because this was my first EVER vehicle to never leak so much as a drop of oil.... I also noticed a very tiny spot of antifreeze. So I drive it home, and place a piece of cardboard under the truck over night to see if it was going to leak again, sure enough it did.
:fire:
I took a look up and found many things I was not happy about, but luckily, I am not going to describe, I took pictures instead.
A few things, the coolant is VERY green becuase I put UV dye in it to try and find the leak, BEFORE the rad was replace... also I have no idea what this thing is in front of the radiator. I am thinking possibly a oil cooler, but I am not sure.
Specs on my Truck:
1996 Eddie Bauer
V8 AWD
4R70W Transmission
163,5XX Miles
Pictures:
This is the Oil Cooler Thing I am talking about.
The underside of it.
It may be leaking from here? IDK.
Where the lines go...It doesn't look good to me.
I am simply pissed off about this, you think the guys who replaced it would clean this stuff up a little bit.
This is where the coolant has been showing up at FOR WEEKS, this is looking strait up to where the puddle forms.
Any input what so ever would be a good help to me, I am way too pissed off to even think about this anymore. but please throw around some ideas or opinions.
Thanks, Harold.
Specs on my Truck:
1996 Eddie Bauer
V8 AWD
4R70W Transmission
163,5XX Miles
Pictures:
Thanks, Harold.
