icu400
- April 18, 2004
- Austin, TX
- '95 XLT
Hey guys. I haven't posted much in this forum, but I have a few idea's on what to do with some LED's and I would like yall's input on how this would work.
First of all, if you check the second page of my cardomain page, you can see the custom speakger grills that I made for my doors. Unfortunately, while they look pretty tight, they is a unsightly bit of metal behind each one. What I want to do is cover that area with black vinyl and add a blue LED or two behind there.
My current plan is to wire a relay so that it is triggered when my amp turns on, power connected to the amp as well, grounded of course, and then run 4 wires off it to connect to each LED (4 doors, 4 grilles, 4 LED's). Then I would need a place to ground the LED (which I would wire in series with the resistor, resistor coming first on the power wire, right?). Any thoughts?
My next thought is to put a blue LED on the underside of the subwoofer grilles for my subs. I am ordering 2 infinity kappa perfects and I think some blue LED light would make those white aluminum beauties shine
. I would power those LED's probably off the same relay, maybe a different one. I would run the wires under the metal of the grilles. Haven't gotten the grilles yet, but again where could I ground the LED?
And finally I am for sure going to do the LED mod with the over head lights and door lights. But I can't seem to find how to pop that plastic cover off the dome light. I have a 95 explorer, how do you do that (afraid of cracking it). Thanks guys!
