I have read all the previous posts and can relate to the "humming" noise, the disappearing or getting worse when turning right or left. I also replaced my left front bearing. (I have 4 wheel ABS, so my new hub came with the ABS cable. If you have 2 wheel ABS, you can get the bearing without the cable - $10 cheaper.) The "hum" actually got worse after I replaced the wheel bearing! I then jacked it up and started looking for other possible problems/sources. I found that the nut was missing on one of the two bolts that holds the front axle to the truck!! I fixed that little issue and the hum was reduced significantly but did not go away. I'm definitely going to try the stethascope thing. If it is the rear bearing, it sounds like it's not something I can fix in the driveway. Right?
