pufferfish
- December 9, 2006
- Baltimore
- 97 Mounty 5.0
headers
torque monsters won't work with the 351w. cast iron log manifolds will work, but flow is crap. stock explorer manifolds won't work. custom is the only choice. after i had created my headers, which look pretty good and should flow well, since they are 1.75 primaries and follow the rules of scavaging (primaries feed into the collector in the order of their firing), but there has to be something easier! i got to thinking about stock manifolds again. the chevy LS engines use cast iron manifolds that flow pretty well. they are block hugger style and since the LS changed to non-siamese ports and nearly identical bore spacing, they actually line up with the ford ports. you might have a cheap and easy winner if you took these manifolds, cut off the head flange and welded on a ford head flange.
also, the corvette LS manifolds are formed sheetmetal, which would be lighter and easier to weld, but they may need further modification s on the collector as they exit near the center of the manifold, rather than towards the back. food for thought.
