lift kit question?? | Ford Explorer Forums
lift kit question??
Basm917
New jersey
2003 ford sport trac
hello there, i have a question about a lift kit, i know i seen alot of threads about it, but my question is do they make spacers that you can lift you ST with meaning spacers that sits on top of you shocks??
The 2003 Sport Trac should be a torsion bar front, that means the lift kits for the 95-2001 Explorer fit,,
there's only 1 tough, the Superlift,, and it's spendy,,
yes yes, i did read about that the TT but just scares me, because i have a 4WD, and i read that it can screw alot of thing up..
only if you go too far with it,,
1 1/2 is safe,, that is about what i run, and i have a ton of miles on mine with the tt,,
if you do the tt make sure you get an alignment after or it will wear out tires, and the wallet pretty fast,
hey guys new here i have a 96 sport looking to lift a little to clear 31's with a little room to spare i was going to do shackles in the rear but thats not my concern im more worried about doing the tq twist in the front but worried about the stress on the torsion bars..... has anyone had any failure up front with doin this
OH, okay another question at the TT, i went to get an aligment done and the aligment guy messed with the torsin bar so naw i dont know how to level it and my truck sits loop sided or where 1 1/2 spose to sit.. and should i just go with shackles in that rear?? thanks for all your help BTW....
not that i have ever heard so far,,
one guy i know broke a t bar, but he was running it pretty hard off road when he did it,,
