I took a tape measure and checked my wheel well height front to back my rear is about 2" lower should I get an add a leaf or make some blocks for the rear to level it out
That very well could be brianjwilson but either way it will be way higher in the rear than the front. you would have to get a 4" superlift kit for the front or straight axle it to get it level again.
Yeah, I'm pretty sure its around 6''. Just go with the shackles. $75 for the pair and worth every penny. If they lift the back to high for you, just crank the torsion bars to level it out.
AAL= 1.5"... Shackles=1.5"-2"...Problem solved. Or you could through some F150 leafs on there AND do AAL AND do shackles for even more hieght. IT's up to you man but spring over is going to be huge. If it's sagging that much in the rear...you need new springs. Personally if I were you, what I would do is...either AAL & shackles OR new leaf springs and shackles only.
