lift options for 99 Mountaineer? | Ford Explorer Forums
lockednloaded
Tiffin, Ohio
1999 Mountaineer
I have a 1999 Mountaineer and am curious on what I can do to lift it. It is bone stock right now. Post ideas and if pics are posted, please post what lift and size plus tire size. THanks!!
depend how close to the sky you want to be... if under 3 inch I propose ReadyLIFT Leveling Kits. Works well and cheap( just bought one a autoanything.com
If higher than that, well you have to go into big works and there better guy than me to help you.
Show pics when done!!!
You can do the Warrior shackles and do a torsion twist. 255/75s look good on it but the biggest you can stuff in there are 275/75s
Body lifts
Couple suspension inches depending on what you have in the front
SAS
Possibilities go as far as you want
Is there a suspension kit I can get to get about 4-5'' of lift? I know it maybe more but would rather stay away from a body lift.
Ok, well change of plans, not going to go full suspension lift. Looking probably just 31's and minimal lift. Did some searching and just going to try and find some better rims and do a wider stance but aggressive.
Can I put 31's on and no lift? Cant find anything about that on here. I eliminated the running boards and really would like to not lift it if possbile.
