liftgate brake light HELP!!! | Ford Explorer Forums
EBexplorerAZ
Tempe, AZ
93 Eddie bouer
i have a 93 eddie bouer explorer, i am having trouble with the 3rd brake light on the lift gate. I can't get the light out to change the bulbs. I took the two screws out but it's still won't come loose.
ANY IDEAS???
My 94 was like that, just pull on it a little some times it seals it self to the truck, just get your fingers under the seal on the outter edge, that is what I had to do on mine
Yep mine was tight too, but probably not been removed for ever. Just work it a little it will come loose.
You might have to put a little screwdriver either inbetween the outer plastic and the X, or in the screw hole to get it out...good luck:D
