light in keypad? | Ford Explorer Forums
light in keypad?
alphabets13
2004 Mountaineer Premier
there is supposed to be one right? if so, mine is burnt out. how do you get to it, take off the door panel and hopefully its right there?
There is supposed to be one. Mine has been burnt out for years. Just keep practicing your code in the daylight, and it becomes like 2nd nature.
thats what i already do. i just figured if it was easy one of these days i would do it. the thing that got me was my manual has practically every bulb in my x listed but none for the keypad. although in the programming your keypad section it says it should illuminate when you hit the #s.
The bulb in the keypad is not replaceable. Ford wants to sell you the entire keypad. I've never looked at mine with the panel removed, but if you could find out Ford's supplier for the bulb they put in there, you could probably find one that would work. Ford only stocks the keypad assembly and doesn't list a part number for the bulb. I'm sure an Engineering drawing would probably show the break-down but good luck getting your hands on that.
i thought it would be just one of those wedge bulbs like everything else. i'm just gonna take the door panel off and see what i can do, but i am not paying $ to ford for a replacement keypad when all i want is the light to come on. its not that important. thanks for the info though.
Buld Replacement
Any success on the bulb replacement. Mine is burnt out too! Let me know what you found...how to remove the keypad or bulb.
I doubt you will find a replacement bulb for it. The replacement keypad will be about $25-30 (at least thats what I paid for mine) but the bulb will be just as much as the keypad by the time you get done with it. Don't worry the keypad is a cynch to swap out.
$25-$30 - - where
Matt,
Where did you find the part for $30 I would like to know so I can order one myself
whoops, I got it confused. When I did the keypad mod in my truck the handle cost $35 and the keypad cost $60. Sorry about that! It was www.fordpartsonline.com
I'm lost
What catagory is it in do you remember?
I actually called the guy to get the price. The actual name of hte product is "door lock actuator assembly"
