Caution
CAUTION!
Be careful removing the horn/airbag module from the steering wheel! Don't even think of touching it until you have pulled the NEG battery cable and waited about 5 minutes for the failsafe system to purge. If you remove the two bolts holding the module in place before disconnecting power, you seriously run the risk of causing the bag to deploy. There's enough force there to break your neck if you're in the wrong position. As a matter of fact, you should always remove the NEG cable before doing any work on any vehicle. Ever hear of someone getting in and starting the vehicle while some poor dude was working underneath? S**t happens!
