Lights Out 1996 Exp 2 wheel dr 4.0 | Ford Explorer Forums
macdowell
charlotte, nc
Hello all - I'm new to the site - I was at the auto carwash the other day - and after the wash and dry - my primary driving lights and high beams do not function - my parking lights work but not the primary driving lights - I bought the vehicle used, so i do not have an owners manual to see what fuse(s) correspond to the lights - can someone help me out? what other things can I check - everything worked fine until the car wash - now my trucks clean and I can't drive at night - hahahaha Look forward to future correspondence with my fellow Explorers -
Thanks in advance - Fred 1996 Ford Exp - 2 wheel drive 6 cyl 4.0
Hello all - I am happy to report - after some great suggestions i pin-pointed my issue, and have lights back :) I tried to find the LOM by removing the center console cup holder and compartment, but did not find an lom??? So then I checked ALL fuses, found none blown, and low and behold, the last and probably should have been the first, I checked each bulb, sure enough both were blown, apperently they weren't seated all the way in, and when I went to the car wash and the water hit the very hot bulbs, the blew - hahahahaha go figure, so as a suggestion always check your bulbs first - hahahahaa will save you some time and frustration - thanks to all who responded, and thanks to this sight for giving me options to check - I would appreciate if someone could tell me where my LOM is located - because when I removed the center console, I did not see a module - Thanks again :) Fred
I think it is your light switch,Because i had the same problem.now its fine
Check your switch.
