lil help with my amp setting | Ford Explorer Forums
superxplorer
michigan
95 xplorer sport
hey everyone i did a search on amp settings and did not find what i was looking for.
so i wanna no what amp settings i should set the knobs at. im gonna be installing the amp in the same location as were the factory amp is so i really canty adjust the amp more then one time realy.
the settings i have on my amp witch are probly the same for all amps are
input level, hp adjust, lp adjust, bass adjust, treble adjust, hp/lo/flat select and bass/trebble on/off.
so what should i set me controls at
thanks everyone
i may be able to help a little.. for the input level, turn your stereo up to your average listening level. then turn your input level up untill the speakers distort then crank it down just a bit. correct me if im wrong but you can only use 1 of the hp lp or full settinng at a time? if so id use the lp and set it to where you like it. the lower frequency the less vocals come through. as far as the bass, treble etc i never had them on the amp. id adjust them to how you like it. after saying all that i hope this amp is just running your subs.. hope that helps a little if not theres alot of knowledge here that will jump in. good luck
thank you but i do have 2 differnt time of setting controls for the hp and the lp.
here is a link to the amp i have. if u click the to enlarge picture then they give you a shot of all the controls.
here
is this amp running subs or door speakers or both?
4 new kicker rs5. front are componets back are just midbass.
well that sounds like a nice system. i only know the basic stuff so i let the experts here help you out. good luck.
thank you. ive read alot on this forum and have always seen you answering to post with good answers. guess this ant your strong point huh. but thanks alot.
not really, i could tell you how id do it. but like you said im not the best on it and if its gonna be a one time setting id rather someone else with more experience to help you with it. i would like to see some pics posted as im sure lots others would to when you get it done. seems like a nice setup.
o ya ill have pics posted. i got some of my car right now but dont know a good server to host them yet. any ideas. but anyways how would you do it. u are deffinetly more exspirenced then me so any help will be great.
i misunderstood what you have. now i think i know. and with that setup im really not sure . but dont rush it. give this post some time if you dont get any help bump it tomorrow. wheres the audio guys when ya need them!!!
k
lol ya but tomarrow i wanna install all my stuff and work. i work for my dad as a mechanic so i have all the tools and everything there.
o ya here are some pics of just of my car and no audio yet.
here
looks very nice. nice hood. if theres anyway to hook it up with mounting it where its a pain in the a!! to get to just temporary id do that till you know you got it the way you need it.
ya i can probly install it all and then leave the left panel off till i figure out what to do. o ya i got another question tho u might be able to help me with. i wanna run ann new speaker wire but how should i run it to the driver side door. there is some kind of weird plastin thing.
on the inside of the door near the hinges? like a rubber tube?
its like a plastic tub tho instead. i no the psenger side is rubber.
its probably the same thing except a replacement. it should come out the same way. a flat screwdriver and a little tug.
aight thanks alot for your help. hopefully someone will give me an answer for the amp before i go to work.
