Matt - It's good to hear that a rear locker works that well. I hope that'll be the case for me. I'll probably be chickened out before I will reach the limit of the truck with the rear locker now.
BExplorer - Unless you live in an area that snowed all the time and the streets snow covered, I would not recommend keeping it in 4 wheel drive mode all the time. It will wear out your drivetrain and you could end up breaking something. The front tires will always do that because on hard surface it has the maximum traction with the road, there is no give on hard surface so it will bite and grind. It probably isn't your hubs if you don't hear all that grinding noises driving straight.
In an open differential, power is still applied to all tires with contact on pavement, only in situations when your tire slipped/spun or is lifted that all power is transfered to the lifted tire.
When you turn hard in the snow and the front tires slide, it's probably because of momentum. It's harder for the truck to turn and change momentum in a slippery condition. You may have to go much slower when turning and not give it too much gas. May be time for new tires?
[Edited by kvo on 07-24-2000 at 10:29 AM]
