So quick follow up to the transmission swap, again I am not a mechanic and this is my first trans replacement. So I got it in and all back together only to start it and ATF poured out the cooler lines. Well, I sort of rounded one head as was told it was a 16mm, which works but not well, a 5/8's works much better and tighter, also a stubby open-end wrench is key for this fitting, or a cut 5/8 flare wrench as room to tighten/loosen cooler lines is tight. Due to the slight rounding of the nut, I was worried about tightening it down so I ordered new cooler lines, waited 2 days got 1, still waiting on the other. Installed the new line, went in smooth as butter, re-connected the other one as it was good, started up and ATF poured out again. So after some serious research, I found out that there is a transmission line connector that inserts into the transmission housing and THEN the flare nut cooler line connects to that, that was not in my book, YT video's, here on EF, or on the transmission paperwork, my dumbass was screwing the lines directly into the transmission, again NOT a mechanic. So attempted to find the part, simple right?? Ford stealership is back-ordered with ETA of April this year with no update, past due, Autozone can not get, although on-line says in-stock, Oriellies can not get, advance can't either, Amazon does not have it either, and My old tranny left 1 hour before I got to Autozone to remove connectors so...... I went to several local shops and looked at the old transmissions they had laying around. Finally, NAPA was able to order them with an ETA of 7 days, so long story short, 5/8 open end stubby, or cut 5/8 flare wrench about 6" long, and remember to remove the Transmission cooler lines connectors from your core tranny, and don't send your core back until the job is complete. Even though it is for a GM, a Dorman 800-811 is supposed to work, I hope so!!! While the install and re-install of everything I had to remove out of the way went smoothly, this is simply operator error and dumbassery all the way. Also, a 2x8 and my Daytona 3 ton floor jack from Harbor Fre worked better than the trans jack adapter for little floor jack, absolute garbage seriously tall, it's like 14" from floor to plate, but the Daytona and wood on the front side of the pan, straps worked great, and you can disconnect the transfer case from underneath, easier to handle separately and regular ramps were tall enough once remove the neff bar. Hope this helps someone viewing these threads later looking for advice on the 5r55e.
