dgr6853
- January 14, 2010
- Stockton, Ca
- 2003 Lincoln aviator
I have a 2002 xls with the 4.0 such. It has a 5r55w and was rebuilt a few years ago at AAMCO and wasn't really driven. if I had to guess it wouldnt have more than 10,000 since the rebuild. The bands and clutches are grabbing. However, I think there is a problem with the valve body and or the solenoid and or the electrical wiring.
when the trans is cold (first few miles of the day) it runs and shifts gears smoothly. However, once the trans is warm it will struggle to shift from 2nd to third. Im not sure if the band pistons actuator was bored out during the rebuild. However, every solenoid is reporting malfunction and electrical problem, including the TCC lockup solenoid.
Once the trans is warm, third will flare and will not always properly grab and I have to slow down and run through first and second again for it to grab.
Once the trans is warm, when coming to a stop the trans will grab first gear really hard and thunk into gear.
once the trans is warm, it will take about five seconds to go into reverse and again will engage really hard with a thunk.
Thoughts? I was thinking new VB, gaskets and solenoids.
