mplspug
- June 18, 2003
- Saint Paul
- MN
I had one of these go out on me with my previous truck and it's a pretty easy fix. My current truck is having similar issues and I am going to swap out a FPR I have tonight. I am also thinking it is possibly the fuel filter?
My questions is with the following symptoms, do you think I am on track? I know nothing is 100% and you'd might want more info, but this is what I have for symptoms.
- Refuses to cold start (need to put into gear immediately after giving and hold gas to keep from stalling. This problem got worse over the weekend when I drove it 60+ miles one way both to and from a cabin.
- No problem starting once it is warm.
- Will die if I am coasting (foot off the pedal), until it warms up
- It runs rough if I idle in gear at a light. Wants to lurch. But idles better out of gear.
- New symptom is on a cold start if it dies, there is a quick noise from under the hood like pressure being released. May just be related to it dieing while I am give it gas?
- The fuel pump is new, however it has always made a high pitched noise when I stop since then. I can stop it by relieving pressure by loosening the gas cap.
With those symptoms, does anyone have a probable cause?
Thanks in Advance. I'll let you know if the new FPR fixes it.
