Stynx
- April 11, 2022
- Springfield, PA
- 2005 Explorer XLT Sport
We recently started getting a warning beep while driving around. It happens intermittently and there doesn't seem to be any message on the display. No CEL or other warning lights either and the dome light does not come on. But it's the same beep you get if you open the door when the vehicle is moving.
I noticed it happened right after hitting a bump, so my working theory is that either the door indicator switch (or whatever it's called) is faulty or that the latches are worn and may not be holding the door as tightly closed as previously.
Where are the switches located? I looked around and didn't see anything. Also can the latches be adjusted?
