JB-1956
- February 9, 2011
- Alkborough, North Lincolnshire UK
Hi guys, I have a 1999 Explorer that loses its drive.
Acquired it recently knowing there was a transmission fault, the previous owner says it needs the torque converter replacing but I’m not that sure.
The symptoms: - I can start it up and shift into reverse. Engaging the gear seems a little slow but then I can reverse and stop. I can then shift to drive and again it seems a little slow to engage. I can drive forwards around the field up to a max of about 15-20 mph due to the nature of the terrain. I can stop and reverse then shift into drive again and drive around the field again.
I can repeat the process several times as the engine warms up but then suddenly I stop and shift into reverse or back into drive and there’s nothing there. I can rev the engine with the transmission in drive or reverse and although I can feel a hint of drive, it’s not enough to move the truck.
The loss of drive does not happen gradually, it seems to happen once I stop and shift through neutral.
Does anyone recognise the problem and have any idea what the problem might be?
